Cannot install MAX version 2.2
NI Daq 6.93 does not properly install.  Some remant from a previous higher version might be interferring.  Is there a program that will "remove all versions and vestiges of NI Daq", including any hidden files and registry entries?
(2,840 Views)
Hi JH Anderson,
Usually in order to uninstall everything from National Instruments, you can go to Add/Remove Programs on your computer and select to Change/Remove National Instruments software.  Then select everything in that tree and remove the software.
I'm not sure if you had NI-DAQ 6.8 before this version but it is not in the Add/Remove Programs view in the Control Panel.  Please let me know if this solves the problem. Thanks!
Vanessa L.
(2,809 Views)
