Cannot install because of previous version?
There is still no solution for this?  I've asked all my instructions at school, searched the internet and nothing.  I've tried copying the CD contents to HD and installing and the problem persists.  I've tried intalling labview 8.2 and 8.5 same problem.  I can install either on another computer without problems just not on my labtop.  Still looking for a solution.  I am not impressed with all the problems related to installing this software.
Nick
Starving Student
Message 11 of 31
(2,780 Views)
Hi Nick!
Is there an error code with the message you see? Is it possible to post a screen shot of the message?
Kristen H.
Message 12 of 31
(2,762 Views)
Hi all,We have similar install problem and the version is Labview 8.6.We installed Labview 8.5 successfully on the HP notebook before.But when we want to update the software to Labview 8.6, it failed.We cannot find software installed from NI right now in control panel of PC. And when we want to install labview 8.6,the error show up.
We found that the DVD of Labview 8.6 were double layer, and our DVD reader couldn’t read them. Is that the reason we can’t install the software? We have already tried to copy the files from DVD to HD, but it showed same error.
We also list the software in the document attached. Is it the reason because of the conflict between softwares or drivers.
Is there anyone who can help with this?
Thank you a lot.
Message 13 of 31
(2,751 Views)
Have you been able to find where the program is installed in your computer?
Open your Command Prompt.
Type : WMIC
then press enter
you should get a prompt,
type in : product get name,version
This should generate a list of installed programs.
To uninstall, once windows has located the program,
type : product where name="NI LabVIEW Full 7.1" call uninstall
This would uninstall LabVIEW 7.1. Do this for all listed LabVIEW software, toolkits.
Make sure you type in the name of the software verbatum
Message Edited by Cory K on 03-06-2009 11:13 AM
Cory K
Message 14 of 31
(2,740 Views)
Hi Cory,
Thanks for your response.
We will try your suggestion and feedback later.
Message 15 of 31
(2,731 Views)
Hi StephenChen,
I cannot open the image of your error message because I do not have Microsoft Office 2007.
Could you resave and post the image in either a .doc (2003) file or as an image file (.png)
Cory K
Message 16 of 31
(2,728 Views)
Here is a screen-ErrorMsg.shot of the error msg.
Nick
Starving Student
Message 17 of 31
(2,711 Views)
Here are the results from the wmic command.
wmic
Nick
Starving Student
Message 18 of 31
(2,709 Views)
Hi Cory,
Here is the Error message document.
Thanks for your help.
Message 19 of 31
(2,673 Views)
Bump, anyone? help please?
Nick
Starving Student
Message 20 of 31
(2,653 Views)
