Cannot load Front Panel Heap.
I have a DSC driver written which works on my development machine, but when I install it on a machine with the run-time only, I get the message, "Cannot load Front Panel Heap." The server tries to open a dynamic VI (which is linked in properly), and passes a reference to a boolean control.
(3,103 Views)
When you built the executable and then included the other VI as a dynamically called VI. Did you tell it to include the front panel?
(3,103 Views)
