Cannot locate Network shared variables in PSP browsing
I created network shared variables on one PC and deployed the library. Then on a separate PC (which is on the same network host), I created a new project and tired to bind new variables to these ones using aliasing. However when I tired to browse with PSP, I could locate the first PC but it did not show any network shared variables. Kindly suggest me what can I try to solve it.
Best Regards,
Shah
Message 1 of 8
(5,549 Views)
Hello svds
Have you tried to use the Distributed System Manager in order to see all the variables in the network?
https://www.ni.com/en/support/downloads/software-products/download.distributed-system-manager.html
Regards
Message 2 of 8
(5,500 Views)
I monitored them using distributed system manager, however, the variables created on computer show up under Network Items->Computer name. But they do not show up when I try to view them through other computer using Distributed system manager.
Shah
Message 3 of 8
(5,494 Views)
Hi, you may need to configure your firewall on the machine hosting the variables.  see here: https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation...
It is worth disabling your firewall briefly, just to see if the firewall is the issue.
Message 4 of 8
(5,491 Views)
Hi Michael,
Disabling the firewall worked with following observations:
1- I only need to disable firewall on the PC that publishes the variables. The one receiving it can have the firewall ON.
2- The method recommended here https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation...  , did not work. I created the required file and changed the number of ports to search from 100 to 1000. The issue persists.
I guess I need to look more into accessing labview through Firewall. Thanks a lot for your advice!
Shah
Message 5 of 8
(5,479 Views)
I looked back and found i emailed NI, here you go : Shared variables require port 2343 to be opened for UDP and TCP as can be found
here:
https://www.ni.com/docs/en-US/bundle/labview/page/configuring-firewalls-and-network-address-translat...
I have asked NI to update the document.  And you are right, these settings need to be added to the machine serving the variables.
I hope that works for you.  Michael.
Message 6 of 8
(5,475 Views)
Hi Michael,
Sorry for delayed response. It turned out that I ONLY had to put exceptions for tagsrv.exe and lkads.exe in my windows firewall. I did not had to change any TCP ports etc, I only had to enter new rules for these two files in the inbound rules of firewall. Thanks for your support.
Shah
Message 7 of 8
(5,455 Views)
Same problem and this was helpful, solved my problem.
Thank you
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 8 of 8
(4,830 Views)
