Cannot locate installed LV Modules Training
I am directing this question to NI. After installing the "LabVIEW Modules Training" there is no way I can locate a trace of it neither in LV, nor in the folder tree! There is no hint nor info during installation that points out either the activation procedure within LV, or the location of the content. I can only verify that it has been installed in the "Add/Remove Programs".
Thanks in advance,
(3,605 Views)
Hello golubovski,
There are a number of training modules available from NI, but I don't recognize the name "LabVIEW Modules Training" . Can you give me more information as to which training module you have installed and I will do my best to help.
David Corney
Customer Education
(3,593 Views)
David,
This is the link to it:
http://zone.ni.com/devzone/cda/tut/p/id/6929
Regards
(3,585 Views)
hi
Please check in this path...
I also have already installed it and i havent faced any problem.
C:\Program Files\National Instruments\Shared\NI LabVIEW Modules Training
by the way which version of labview you r using...
the installer will also install Labview runtime 8.5.
(3,579 Views)
Hi golubovski,
   Look under Start>>Program Files>>National Instruments>>LabVIEW Training
-Nick
(3,565 Views)
