Cannot open Excel using Activex
I have office2000 and using activex I can only open word and powerpoint but not excel... Everytime when I try it gives "Error -2147319784 occured at old format or invalid type library." Thank you very much for any help you provide about this problem.
(3,667 Views)
The link below may offer some clues.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000852F0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
(3,667 Views)
Please first check that you are using Excel 2000 examples.
This error we have only seen happen in a very few specific cases. Usually this only occurs on a system that has a foreign language OS of some type installed. The fix below may not work in all situations, especially, if you are trying to use Word as your ActiveX component.
Error -2147319784 is caused by LabVIEW failing to recognize the typelibrary for certain ActiveX components. Note: At this time we are only aware of this not working for Microsoft Office Products.
To fix this problem, you must modify your Windows Registry file.
Warning: Deleting or changing the wrong entry in the Windows Registry could render your computer unusable! National Instruments takes no responsibility for errors mad
e by modifying the Windows Registry.
Here is how to modify the Windows Registry:
Launch the Registry Editor. Go to Start > Run and type regedit at the command line. Press OK.
Under HKEY_CLASSES_ROOT locate the TypeLib Folder.
Search for the Excel or Word key. It should be some long combination of letters and numbers such as:
{00020813-0000-0000-C000-000000000046}
There are two base keys named "1.0" and "1.2". Under the "1.0" key, right-click and create a new key. Name it "0" (zero). (See the attached images, Registry_Before.gif and Registry_After.gif.)
Under the new "0" key, create another new key called "win32".
Under the "1.0" > "9" > "win32" key you will find the path to the Excel5 or Word-library on the machine. Copy this path into the key that you created in the previous step.
Exit the Registry Editor, saving your changes.
Launch LabVIEW.
Zvezdana S.
(3,667 Views)
