Cannot open NI-DAQ examples vi
I'm having a problem when I open DAQ-examples, sometimes also the NI-MAX does not run properly.
I have LabView 2020 SP1 and LabView 2021 (21.0) on Windows 10 and there is the same problem for both versions.
Has anyone had the same issue?
Thanks in advance for your help.
(1,031 Views)
Hi Denny,
Does the VI open completely/correctly when you wait longer?
I see this behaviour when the MAX database has been corrupted. Usually it helps to open MAX and reset the database
(1,020 Views)
Hi GerdW,
the VI won't open even if I wait longer.
I tried to resetting the MAX database and also to repairing the NI-MAX package, but I didn't fix the problem.
Denny
(1,014 Views)
I tried to completelly unistalling LabVIEW and reinstalling it, but i can't seem to fix the problem.
Could it be a windows updade that conflicts with something?
Denny
(970 Views)
