Cannot open a labview project
I am trying to open a labview project from my account in a pc, and it says project or library file cannot be opened. I try to open the same project from same pc but my boss's account it works. I try to open some individual VIs in the project from my account, it works. I even tried to open a different project from my account, it works. But this one project, i cannot open. Does anyone know what could be the reason. The admin has given me access rights to the folder. But then we checked opening the project from the admins account and it still doensnt work. Only with my boss's account it works.
Thank you.
(1,441 Views)
Hi govindsankar,
Please attach that project file so we can inspect it…
(Or work with your boss's user account!)
(1,426 Views)
the problem is solved, i dont know how. my boss did something and now i can access it. Thank you.
(1,422 Views)
Hi govindsankar,
You should ask your boss to learn such things!
(Otherwise you don't learn and need to ask each and every time…)
(1,396 Views)
Sounds like some access rights has been changed.
Qestit Systems
Certified-LabVIEW-Developer
(1,224 Views)
When LabVIEW asks you to recover a file that was open when it crashed, it recovers it from the user's profile, so it will have the user's rights. This can be an issue if the computer is locked down tightly.
Bill
CLD
(Mid-Level minion.)
(1,171 Views)
