Cannot perform web publishing
Have enabled the web publishing and have previewed it on web browser that is on local machine. But when entering url at another machine it says it cant locate the server.
(3,416 Views)
Hi Mark,
first check if you have a network path to your server. You can do this using ping from a console window.
Maybe the other tracks can help you:
I cant watch my VIs published on web using Netscape
Web browser plug-in for publishing a front panel
Have you checked the settigs under "Tools>>Options>>Web Server : Browser access" that the requesting machine is allowed to connect?
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,416 Views)
I will check network path. Have checked the browser access and have allowed all browsers access. Have the server enabled as well. Thanks for the response
Mark
(3,416 Views)
You need to have either the LabVIEW development or LabVIEW run-time environment installed on any system that you wish to view the embedded webpage.
(3,416 Views)
Have labview development installed on machine that is trying to view page. Browser still cannot locate server with web server enabled and URL that web publishing tool assigned.
(3,416 Views)
