Cannot read FFV1 avi file
Hi all,
i recorded some avi file in Labview from my USB camera. I specifically choose the FF Video Codec 1 (FFV1) (NI Vision) because it was the only one with full quality (i used the codec example from NI to see which one gives me the best quality).
The problem now is that i cannot read it in Labview anymore. I can tried it in my own written software as well as with the example vi from NI. But nothing works. The only software which can read it is VLCplayer (it says it has a broken index but can still play it)
I don't know what to do...Can i convert it somhow? Or better is their a way to open in Labview?
Thanks for your help!
Eggord
(2,550 Views)
Hi Eggord,
I am working on the same problem. Can you let me know if you have found any solution for it?
Thanks in advance.
(1,636 Views)
