Cannot see the errors when starting Tag Engine
I am trying to start the tag engine with a very simple .scf file and when it starts it immediatly shuts down and says "ERROR - No servers launched". Is there any way of finding out more detailed error information, or is this indicative of something obvious I am doing wrong. the only sucessful launch of the engine was with the default.scf file.
Thank you,
rforrest
(2,951 Views)
Try running vi.lib\lvdsc\_dsc.llb\dsc_DYN_CheckAllSrvrs.vi. Does it report any errors? If this doesn't fix your problem, what servers does your porcess use?
Robert
(2,951 Views)
I am using the Datasocket server with tags connected to the Datasocket items. The tags themselves indicate that there is a problem "That Configuration is currently not valid." Says the Tag Configuration Editor. I cannot get the Engine to run with any Datasocket items as tags. Any ideas?
rforrest
(2,951 Views)
