Cannot use Median Filter inside While Loop
I am trying to use the median filter insade a while loop. This seems to be causing a problem. I have attached the VI. Please help.
This input is a sample numbers such as 1,1.1,1.05. This output is zero.
Venkat
(3,294 Views)
Accepted by topic author venkat_rao
Since you only get one value per iteration, you might want to use the point-by-point version of the median filter.
(3,292 Views)
