Cannot use custom scale with AO on usb-6008
Using a usb-6008.  Using a custom scale for ai0 works fine (input).
But I get the "Custom Scale Does Not Exist" error when using the same scale with ao0.  Seems to work fine if I don't use a scale.
Tried creating the scale within the code as well as setting it up within the project.  Neither works.
(2,991 Views)
Hello Jed,
Have you tried following these steps?
http://digital.ni.com/public.nsf/allkb/2DDF9EB699D63B4386256F0400675F69
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,976 Views)
I believe I tried this- but the error is not a range error, the error is "The scale does not exist".
I know it exists, because during my troubles I tried using the same scale I was using for an AI task (just to see if it detected it) and this would not work (the ranges are valid in both scales, either direction).
(2,973 Views)
Hello Jed,
Can you share the VI you're using?
Can you also share your custom scale?
This way I can try to reproduce the behavior at my side.
You can export a scale by following these steps:
http://digital.ni.com/public.nsf/allkb/42A2D212796B3DC2862571FF0061B402
Kind Regards,
(2,954 Views)
Hello Jed,
Kind Regards,
(2,954 Views)
I made some sample code that fails. Ill post it when I get home.
(2,950 Views)
