Canoe Event Handling in Labview
Anybody worked on handling the events of CANoe in Labview?
I am trying to handle the event when there is a value change in the environment variable of CANoe. CANoe provides a COM method "OnChange" but i do not know how to implement this method in Labview. This method is available in CANoe -> Application-> Environment->EnvironmentVariable-> then event OnChange.
Any ideas??
Suhas
(7,011 Views)
Suhas,
Unfounately NI does not have any documentation on using CANoe in LabVIEW.  Vector does provide driver software for LabVIEW.  Vector's website may also be a good resource for your question.
Mark
NI App Software R&D
(6,963 Views)
In general, you would need to use Register Event Callback to register a callback VI for an ActiveX component. There's two examples that ship with LabVIEW that show the use of this. Open the Example Finder (Help -> Find Examples), and search for "callback".
(6,959 Views)
  I'm willing to handle the same process as you, but I did not yet success. I attached my project, and I think my problem is more Labview than CANoe. If you successed or if anyone already have done such diagram with VICallback and Event Data, please have a look, I'm really fighting without success now.....
(6,741 Views)
Hello Anthony,
Yes i have implemented this functionality after spending lot of time. Here is an attached vi which will give you some idea, how to register an event.
Suhas
(6,713 Views)
Thanks Suhas,
  Could you please also provide me the callback vi, because with only the first file, I'm not sur to see the big picture...
(6,699 Views)
Hello Anthony,
Attaching the call back vi. you can write your code which need to be executed in the call back function.
Suhas
(6,695 Views)
