Cant Edit Column Headers In exe.
I will try your advice here in a bit, but i am able to edit the column headers before i run it in labview.  I created the executable to not run when opened and i am unable to edit the headers inside the executable. So editing the column headers doesnt work in only the executable
-Matt
Message 11 of 18
(929 Views)
Did you change it to a control?
Message 12 of 18
(928 Views)
When i change it to a control, i can no longer write to the table, which is more important than the column headers.
-Matt
Message 13 of 18
(923 Views)
Use a local variable, or property node with a write to the value to set the table.
If you don't want your users editing the other cells you can use an event structure to handle the Mouse Down? and discard the mouse if it is not over the header.
Message 14 of 18
(921 Views)
That may be getting a little above me, but ill give that a try.  Thank you for the input
-Matt
Message 15 of 18
(915 Views)
Unless im mistaken, it is not possible to write to a control this way.  Ive tried and it has been unsuccesful.
-Matt
Message 16 of 18
(892 Views)
It better be or I'm going to have to re-do my CLD exam.  😉
Bill
CLD
(Mid-Level minion.)
Message 17 of 18
(886 Views)
Which way? Show us your attempt.
Message 18 of 18
(868 Views)
