Cant find a specific fucntion block in Labview functions palette?
(1,543 Views)
Accepted by topic author adis82
"Build Array".  You could've guessed it by enabling context help and hovering over the input wire and then the output wire.  🙂
Bill
CLD
(Mid-Level minion.)
(1,541 Views)
Hi and yhanks for the help. I am not very expirienced with Labview.
I am suppose to build a OPC UA Clienbt Write diagram.
I sort of have the solution, but cant find all the things in the labview.
When I try to connect the Build array bloc to OPC Multiple Write I get an error that says they do not match.
Also I am not able to get this request cluster. How do I do that. When I go directly on the bundle bloc I only get two labels in the cluster.
(1,484 Views)
