Cant transfer an empty file with WebDAV protocol from RT target to local PC
Whenever i try to transfer an empty file with Get file.vi (WebDAV Synchronous) the error status is true ( No errors) .The files with certain size ( greater than or equal to1KB) is copied. But the empty file(0 KB) is not transferred to the local specified path on the computer from cRIO. Does anyone knows the reason for this ?
(1,151 Views)
If the error status is true, there is an error. What's the code?
(1,138 Views)
i mean the status is green and checked
(1,133 Views)
Did you ever get an answer for this issue?  I have confirmed the same behavior.
(420 Views)
