Caption.Text in a Chinese or Vietnamese
Trying doing things in this order:
Message 11 of 17
(509 Views)
Make sure that before any concatenation, all the string parts are UTF-16 LE.
Message 12 of 17
(508 Views)
Thank you Paul.
I don't know how to cast a regular string to a UTF-16 string. Please find attached and down here, the Fi and Vi strings are ASCII, I need to cast them into UTF-16.
I used this, but it did not work:
Message 13 of 17
(504 Views)
Accepted by topic author ngthai
No worry. I was able to cast regular string to UTF-16 string. All good now.
Message 14 of 17
(489 Views)
This is much simpler:
Or, if you want to get fancy, use the attached "ASCII to UTF-16.vi".
Another way to deal with it is to try the attached "Concatenate ASCII or UTF16.vi".
Message 15 of 17
(478 Views)
I continue to have extremely weird responses from Labview front panel:
In Chinese, the probe is:
but the display is backward (i.e., from right to left): ngthai_1-1734011579511.png
Why labview suddenly displaying backward?
However, when I changed to this phrase "严重   " with a few spaces there, then labview is displaying correctly from left to right: 严重    偏心 =3.2 CSI= 20.3
So the problem is solved for me (by not using the ., and use the spaces after 严重). I'm just curious what happened.
Message 16 of 17
(454 Views)
I don't know.  My guess is that you have a mismatch between the "Interpret As Unicode" settings and whether the corresponding characters are actually ASCII or Unicode.  If that's happening, then some characters could be misinterpreted as the wrong Unicode characters; some of which are for right-to-left display.
Message 17 of 17
(446 Views)
