Capture Tx data bits using E4406A LabVIEW drivers
I need to capture the GSM Tx data bits coming into VSA E4406A series transmitter tester by using the E4406A drivers.
Is there is any drivers for capturing the TX data bit?
Please mail me bharathitp@hcl.in
(2,758 Views)
I've not used the instrument but I've looked at the driver and there is a help file included. In the help file is a list of the function calls and what they do, and a list of the SCPI commands cross-referenced to the function calls. If you know the commands that need to be sent, you should be able to determine which functions to use. The driver is quite large and probably includes the necessary functions but if it doesn't, you can always use the hpe4406 Send String to write the specific command you need. Also, since the driver is written and maintained by Agilent, you might want to try contacting Agilent.
p.s. It's not a good idea to post your email in a public forum. Answers are provided to the forum itself and all you will get is a lot of spam.
Message Edited by Dennis Knutson on 11-23-2007 10:06 AM
(2,752 Views)
