Capture Video on Android Camera and Load into LabView
I was wondering if it's possible to connect an Android Phone Camera to LabView while running a test and integrate into my vi. Then be able to Load the video that was capture to the PC. Would it be possible via bluetooth or USB connection.
(1,751 Views)
First, to check the feasibility in LabVIEW, check for feasibility in another programming language, like Python or C#; if you can find examples for that, it may be possible to port it into LabVIEW.
Santhosh
Soliton Technologies
(1,746 Views)
This is already quite old but the principle still applies.
NI Vision does not know how to interface to your Android phone camera. Instead you need to install a server component on your phone that converts the camera into a video stream of some format and then install a IP Camera driver under Windows that provides a DirectShow Interface. NI-IMAQdx then can access that adapter.
Rolf Kalbermatter  My Blog
(1,698 Views)
Windows new version, 24H2, will support control your phone on PC.
George Zou
(1,679 Views)
