Capture and manipulate rs232 binary data
Hello, I am very new to lab view 7 and I need to do the following for work. I am using the rs232 serial port on the computer to communicate with a prototype circuit. The communication is a simple 8bit (byte) of 1's and 0's to and from the computer. How do I take this byte and sepearte it to individual bits, so I can display the results in the front panel? I would need to both create the byte from 8 individual controls then concatinate the bits, and send through the serial port. Also take the byte from the serial port and seperate the individual bits. Thanks alot for any help I can get in pointing me in the right direction.
(3,970 Views)
(3,970 Views)
Wow, thank you very much for the quick reply, it is exaclty what I needed. I am not quite sure what the "data read" and "data out" function is. It works perfect, but it is magic to me.
(3,970 Views)
They are just clusters of Booleans. In the string to Data Out, the binary string is converted to a number, the number to a Boolean array, and then an array to cluster. The bottom is the reverse with cluster tot array, Boolean array to number, number to binary string. I could have skipped the cluster parts and just used arrays but I've found it beneficial for users to look at clusters because then you can rearrange the elements like I did with bit7 overe on the left. If you expand an array to show 8 elements, the least significant bit is the first element in the array and that is displayed over on the left.
(3,970 Views)
Ok, great thanks again.
(3,970 Views)
Use Number to Boolean array.
"jorge" escreveu na mensagem
news:506500000008000000BCC70000-1079395200000@exchange.ni.com...
> direction.
(3,970 Views)
