Capture video card output
I need to build a VI where i capture the output of my video card (my screen...)
I tried doin' it by taking PrintScreen's but I'm not satisfied that way...
Hope one of you guys can help me 😉
Greetz,
Ganux_
(3,120 Views)
What are you trying to achieve?
Do you want to save a picture of the whole screen, one window? Are you trying to record video of what the screen is showing?
For a front panel you can use the FP.Get Image property node. This can be cropped to get subsections. However a bit more detail is required to get you going.
Ian
(3,107 Views)
I'm trying to achieve a conversion from the data from my video card to RGB-pixels.
Then i would sent these over UDP to a controller board my partner is designing.
A next step would be to scale the data for lower resolutions, but that's a next step..
for now it would be nice to get the data from my card, so i can continue with the conversion 😉
Ganux_
(3,101 Views)
The IMAQ vision toolkit will probably be your friend if you have it - searching the forum will pop up lots of similar queries.
I can't help you much as I don't have it and haven't used it!
Good luck
(3,099 Views)
I don't have the toolkit..
Isn't there a way without using this?
using DirectX or someting like that??
Ganux_
(3,094 Views)
