Capturing Images with Black Magic Intensity Pro to process on LabVIEW
I've been trying to use an Intensity Pro 4k card from Black Magic Design to receive an HDMI input and send to LabVIEW for testing. As we can see in the image on the link below, NI MAX identifies the device, but the capture is all black. Has anyone else run into the same situation before? If so, how did you manage to capture the video with Intensity Pro and process on LabVIEW?
Heres what NI MAX shows: https://imgur.com/qWs3OmE. The same thing happens on Vision Acquisition.
Thanks for the help!
(3,306 Views)
Hi Julio,
I believe I need a few more information about our issue to be able to help you:
What is your LabVIEW version? The driver IMAQdx version?
Thank you for the attention!
Isabelle Orlandi
Engenharia de Aplicações
National Instruments Brasil
(3,243 Views)
