Capturing Images with IC Capture extension
I'm able to take pictures with the IC Capture extension, but now I want to create images in a time interval. When I press capture, it should take one picture every five seconds, for example. How do I do that?
(745 Views)
Found the solution
(732 Views)
Just in case someone else has the same question, please "return the favor" and explain how you fixed it.  You can even mark the "Fixed it" response as a "Solution" (which, of course, it would be).
Bob Schor
(682 Views)
