Capturing a segment of a waveform. Once.
Hello everyone.
This vi captures a certain number of pre samples and post samples from a waveform, when trigggered.
However, it continually overwrites these values when the next pre/post samples.
How can I change it so that it captures the pre and post samples only once, regardless of the trigger state.
Thanks guys.
Message 1 of 11
(3,654 Views)
Do you want your trigger to be 'active' for only one capture sequence and ignore all the threshold crossings that will occur in subsequent iterations?
Message 2 of 11
(3,648 Views)
Hello.
Exactly. Basically I want the capture to act on one trigger only and then stop, regardless of any subsquent triggers.
Message 3 of 11
(3,643 Views)
I am kinda lost on this one.
I would appreciate the assistance.
Regards
Tom
Message 4 of 11
(3,588 Views)
You could make a psuedo-state machine out of it.  I modified your code to include an extra boolean shift register.  It starts false and is set true only when a trigger is found.  By inserting an OR statement before the case structure, the shift regiseter forces the case structure to always be true.
I don't feel like I am explaining the changes all that well.  If you have any specific questions, let me know.
Message 5 of 11
(3,586 Views)
Hello Jason.
Thanks for the reply.
I am having difficulty opening the file, I have V7.1.
So if a trigger is found the case is in one state, but then is immedaitely locked in the othe state.
Regards
Tom
Message 6 of 11
(3,580 Views)
Message 7 of 11
(3,579 Views)
It works Jason.
Thanks for the solution and the expalination.
All the best.
Regards Tom
Message 8 of 11
(3,574 Views)
I'm just doing it for the starsRobot wink because almost everthing I know about LabView, I learned in this forum.  And I enjoy giving back.
Message 9 of 11
(3,573 Views)
I forgot to give you the stars with all the excitement, sorry
Here you go!
All the best
Message 10 of 11
(3,565 Views)
