/CarSim/Functional node/ Error msg "LabView Development System"
I am integratingLabview with CarSIm using the Functional node block. Everything runs okay, but after rerunning the program (loop) 3 times, Labview stop working ad send error msg as "Labview Development system has stopped working" with two options to close or debug the program. I dont know what causes this error as well what solutions or alternativs can i do in order to go over this problem.
Please if you have any ideas, feed me back !!.  Attachments are  the files of the program.
(3,666 Views)
Are you checking that your initialization has no errors?
(3,644 Views)
Thanks for your reply.
I did everything works fine for 1st run, 2nd and 3rd. after that Labview just stop working.
Attached is a screenshot for the error while the program is running.
One more comment : When i use a simple single run program ( No indexing and no multi xy charts,  the system works well ).. ....
(3,631 Views)
