Carbon Monoxide Data Logger
I have an enhanced carbon monoxide data logger, Model T15n, which logs carbon monoxide concentrations.  It connects to the computer via usb and I was wondering if there was any way to monitor, i.e., read the data from the logger in a real-time manner.  Currently, all I can do is import the data, that has been logged on the carbon monoxide monitor, into HOBOware, which is the software that came with the device.
(2,624 Views)
You would need to check with the manufacturer to see if they provide some sort of driver or DLL that you can use to control the device from your own program. If the HOBOware app uses a DLL to talk to the device it's possible you may be able to use it as well from LabVIEW, but you would need to get the documentation from them.
(2,616 Views)
