Carrier Frequency on each channel.
Hello everyone,
I am implementing a vi in LabVIEW using NI USRP-2945 with the configuration of the four channels that it has as shown in Screenshot_1. The Carrier Frequency is configured as shown in Screenshot_2 since it needs to be configured later because it is necessary for a frequency sweep loop to be entered into a signal generator. However, even if channel by channel is configured, the Carrier Frequency configured on channels 0 and 1 (external) is not the same as that configured on channels 2 and 3 (internal and companion respectively). Why?
Thank you for your attention.
Message 1 of 1
(2,025 Views)
