Carsim labview live RT animator not working
I am trying to get the live animator running on CarSim 8.0 when using the Labview RT ABS example dataset that comes with Carsim.
When I press Run Now the live animator window pops up showing the road and terrain. However it looks as thought the car animation does not initialise exept for one wheel which seems to be positioned at the origin of the car coordinate system. The car shadow is also present.
Does anyone know how to remedy this.
The only thing in the animator log window is the line FYI: Attempting to connect to '127.0.0.1:5434'...
Any help would be much appreciated,
Sam
(3,813 Views)
Are you trying to run this software on real-time hardware (cRIO, PXI, RT-PC)?
This seems to be tied to the LabVIEW program made by Mechanical Simulation Corporation.  In which case it may be better to contact them:
https://www.carsim.com/contactus/support.php
(3,759 Views)
