Carte NI 4351 pas vue par Labview
Bonjour,
J'ai une carte NI 4351 qui semble bien fonctionner. Avec Measurement & Automation Explorer je visualise bien mes températures pas de soucis. Mais dans Labview ou DAQ, il ne trouve aucun périphérique présent. Qu'ai-je raté ?
(2,942 Views)
Sorry, I get missed with all the forum. I though I post in a french forum. Here's my question :
I've got a NI 4351 card, which seems to work correctly : in Measurement and Automation Explorer, I get temperatures without problem.
But in Labview or DAQ, it can not find any devices. Where am I wrong ?
Many thanks in advance.
(2,941 Views)
Fisrt you need to know that the 4351, uses NI Daq traditional.
Then you need install the Daq trad support for Labview (in order word you need to install Daq Traditional after Labview).
After that you can go to the NI Example Folder, then seach and you must write 415x you will see many examples, you will have to write the good instrument descriptor.
Nacer M. | Certified LabVIEW Architecte
(2,919 Views)
OK. I was able to use an example.
Thank's a lot.
(2,902 Views)
