Case Structure Listing
I've got a case structure with the selector wired to a string input. As it's got a significant number of cases in it, I'm trying to programmatically generate a list of the actual case strings it contains in the selector, without actually executing the structure.
Anyone got any ideas?
FYI; Reason being, I'm trying to write a document containing a description of each case, and I don't want to miss any out!
Many thanks,
Chris.
(2,974 Views)
Personally, I would simply search the 1D array of possible strings for the current string and use the index of the found element to pick a description out of an array of strings with the descriptions in it.
This doesn`t work if you want to operate code based on the cases, but for a simple description allocation it should work.
I certainly wouldn`t use case structures for this if you`re just looking to link a string value to a particular array.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,974 Views)
Thanks for the help, but it's not quite what I'm after.
Your idea could actually be a better way of doing this, but I don't really have the time to re-implment it in the existing code.
A bit more info:
My case structure is in a command interpreter. I parse a line of text from a file, split it into a command string which is wired to the selector. The remainder of the string read is a parameter string which is also passed in.
This means that I can't search the data going in, as it's indeterminable, and hence why I'm trying to programmatically read out the string names of the cases in the structure.
Cheers,
Chris.
(2,974 Views)
