Case Structure Problem?
Yes you are right. May just adding a selection for simultaneous acquisition will do..........
Message 11 of 24
(2,881 Views)
Hi Muks,
Thanks for your vi oh.vi. Unfortunately I cannot open because it is saved as Labview 8. I use only Labview 7 Express. Could you please save as Labview 7 file please.
Nevica
Message 12 of 24
(2,872 Views)
There now it is saved for 7.1
Message 13 of 24
(2,870 Views)
Thanks Muks!!!
Message 14 of 24
(2,867 Views)
Muks,
The version saved in 7.1 won't open either. It will need to be saved in 7.0. If you cannot save it in 7.0 then you could try sending it as a screen shot.
Nevica
Message Edited by nevica on 08-11-2009 06:12 AM
Message 15 of 24
(2,857 Views)
Message 16 of 24
(2,850 Views)
Hi nevica, can you please answer these questions?
So can you please clear out the required functionality of the code:
Succesive use of the three gauges or not?
Use of only one gauge at the time or not?
Always multiple readings until the "Stop" button is pressed or not?
Once we know your requirements, we can proceede with a correct code Smiley Tongue
Some additional questions 🙂
1) Now you initialize the instrument before every reading followed by a delay of 0.3 sec. Is this necessary?
I don't think so, so you should have a loop inside each case structure for consecutive readings without initialising.
2) Why do you need the 400ms delay?
Message Edited by Alain S on 08-11-2009 01:21 PM
Message 17 of 24
(2,849 Views)
Hello Muks,
I am sorry to be such a pain. I cannot quite see what the structure outside of the case structure does. I presume that the case-structure is repeated three times? I am getting lost with the wiring as it is a bit jumbled.
I pressume oh.vi tests which buttons are pressed (outside of the case structure) then I get lost with the wiring.
Nevica.
Message 18 of 24
(2,845 Views)
Accepted by topic author nevica
Attached muks VI for 7.0
Message 19 of 24
(2,843 Views)
Hello Alain,
Yes, the time delays are important. The instrument can only acquire data every 300 - 400 ms.
The time delays are safety nets to ensure that instrument works properly.
Nevica
Message 20 of 24
(2,828 Views)
