Case Structure Voltage Initiation
I am trying to intitate a case structure with a digital input voltage. I know how to acquire the voltage, but I dont know how to convert the voltage into a boolean or numeric function to initiate the case structure. Attached is the code I have so far with a sub vi for the voltage. Any ideas? Thanks.
(3,563 Views)
Follow your create digital channel with a DAQmx Read set for Digital>Single Channel>Single Sample>Boolean.
(3,558 Views)
you did not include the subvi. Remember that when you save a vi
the subvi are not saved in the same file unless it is a llb file (library).
If you want everything in one file try save with options=>developpement for example.
Please post the subvi or the complete library.
Anyway, what is the problem? You have a voltage and a case. What do you want to
do is the first question? When is the case true and when is it false?
When the voltage is lower than a certain value? Explain.
Dai
LV 7.1 - WIN XP - RT - FP
(3,555 Views)
I want the case to be true when their is a 5 volt signal present.
(3,548 Views)
(3,547 Views)
I have added the read function. Is this correct?
(3,543 Views)
it looks ok at least for the part where you read the Digital Input and links it to the case.
Dai
(3,533 Views)
