Case Structure and String
Hello everyone.
I'm having some problems with my VI on Labview. I have as input a String that have in sequence: "Number of Sample/X Value/Y Value/Z Value", each of them separated by a comma. In the serial port I receive a loop of 500 samples from an accelerometer.
I'd like to have Labview receive the values only when the String "Number of Sample" is 0 and graph them until the 499th sample is send and discard the data when is different from 0.
My problem is the Case Structure, I can't manage to send data when the string is 0 and discard the data when is different from 0.
I've attached my VI, any help would be greatly appreciated.
(3,370 Views)
Well, you appear to have LabVIEW 2013.  Did you know about the Conditional Tunnels that were indtroduced in 2012 and improved in 2013?  a quick mod to your code is attached.
There are other opportinities to improve that code but, I'm assuming its only part of a larger vi (and a BD clean-up is in order)  Comments can also help make your code more readableSmiley Wink
(3,351 Views)
Thank you very much for your reply, unluckily it's not working.
I've attached again my VI, commented as you suggested.
Any help is again very appreciated.
(3,314 Views)
Accepted by topic author AndreasSchnaas
Hi Andreas,
the problem isn't the case structure, it's more likely the inproper use of BytesAtPort.
You have configured the serial port to use the TermChar. Then all you need to do is to read a sufficient number of bytes from the port as VISARead will automatically stop at the TermChar. Now you can analyze your data.
For that case structure: You have to output a value on that tunnel. Or you have to include all code, that should only execute in the TRUE case, inside of the case structure!
I also suggest to use the SpreadsheetStringToArray function as your read string seems to consist of several numbers separated by commas. It will simplify your BD a lot…
(3,308 Views)
After some days of work, thanks to your suggestions I've solved my problems.
Thank you very much!
(3,262 Views)
