Case Structure to Obtain 1 Single Measurement
Hi All -
I'm using for DAQ Assistants to measure 4 different voltage signals.  I want to zero them with the click of a button so I am using a case structure and when I click an "OK" button it takes 1 single measurement from each of the 4 signals.  I then want to keep this value and use it in calculations elsewhere in my code.  Do you know how to store that one value and obtain it for use elsewhere?
Thanks!
(2,427 Views)
You can store them in a feedback node or shift register.
(Please show us your code so we can give more detailed advice.)
(2,426 Views)
