Case Structure
I am new to LabVIEW and I have an easy question I guess.
I made a while loop inside case structure ( true case ).
i want the same data to out from ( false case ) but with a little change
When i do this i get new results not the same data i want.
how can i communicate between the two cases
Message 1 of 8
(4,385 Views)
Skip the case structure and use a Select inside the While instead. You either add an empty string or the name.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(4,382 Views)
Accepted by topic author El-Awny
Your code is inside out.
The case structure should be on the inside, the while loop on the outside.
Message 3 of 8
(4,381 Views)
Yes, I just notice that but i faced another problem
when i add Empty String it adds an empty place in the array
I just want not to add anything and keep the place not used
Message 4 of 8
(4,359 Views)
Show your latest VI.  Actually attach it so we can browse through the various cases.
Message 5 of 8
(4,349 Views)
Not sure to really understand what you mean by "keep the place not used".
If you want to add a row only when TRUE, and do nothing when FALSE, then you just need to wire the string array from the input of the FALSE to the output without any function.
Yddet
Message 6 of 8
(4,344 Views)
if it's a user interface you can make one loop and if not you can keep just the select case.
See attached file.
https://images.youracclaim.com/size/110x110/images/7c5d31f5-2069-4618-ba59-b710c2b6bbe4/CLD.png
Message 7 of 8
(4,336 Views)
Yes? That's the definition of adding an empty line. What you want is the Insert (it's probably better with Build Array) to be in a case structure. Either it builds to the Array with a name, or nothing happens.
/Y
Qestit Systems
Message 8 of 8
(4,267 Views)
