Case Structure
I cant figure out a certain thing I would like to do with a case structure.
I should have 4 cases :
1) A and B are True
2) A is True and B is False
3) A is False and B is True
4) A and B are False
After I wire together this boolean logic, how would I wire it to the case structure?
Do I build an array of the booleans, cluster, or what?
I dont think I can use enum (because I havent figured out how I would incorporate it into this situation)
Any suggestions?
Cory K
(4,175 Views)
Cory
Convert the two Booleans into an array then to a U8 which gives you 0,1,2,3.  Wire this to the case structure.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(4,170 Views)
Accepted by topic author Cory_K
Darren did something like this in his last nugget see attached in 8.0.
(4,162 Views)
Thanks jmcbee, that worked.
Cory K
(4,157 Views)
Thanks for this. I hope tihs will work for me
(3,802 Views)
