Case Structure
i have 4 cases in my case structure. after executing case 0, it will go to case 1. inside case 1, there is a Select function. if the input of the function is True, it will output a value of 0 which will be connected to a shift register then to the case selector; if the input is False, it should go to case 2. the problem is it stops doing anything after shift register pass the value to the case selector, it doesn't go to any case. and there is only case 1 having problem. Please help!
Thank you
Message 1 of 8
(4,008 Views)
In case 1, you missed the tunnel with your TRUE constant. Drag that tunnel away and you'll see one connection going to the while loop condition and another going to your TRUE. Rewire the constant.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
Message 2 of 8
(4,008 Views)
What you've done is create two output tunnels from your case structure. Cases 0,2, and 4 have the constants wired to the while loop terminator, but case 1 has the constant wired to a different output terminal that doesn't go anywhere so the default condition of false terminates the while loop.
Message 3 of 8
(4,008 Views)
I would slightly modify your while loop condition so that you can avoid minor issues like the one that you have. Change the condition for while loop to stop on true. Wire the constant 'T' only from cases where you want to stop the loop. The default being 'F' will let the while loop run for the remaning cases.
Message 4 of 8
(4,008 Views)
To: Photon Dan, Dennis Knutson and Anand S R
Thank you all for your help!
Message 5 of 8
(4,008 Views)
So why did you give Dan and me such low ratings?
Message 6 of 8
(4,008 Views)
i didn't give those ratings...
Message 7 of 8
(4,008 Views)
I feel that the rating system in its current form is quite unclear and unecessary.
I just made some comments OVER HERE in the Feedback section.
Message 8 of 8
(4,008 Views)
