Case inside IPE bug results in corrupt vi
I'll post the CAR as soon as its assigned.  Bug reported to and confirmed by NI SST
Steps to reporduce:
Select Case Structure and add so the top left Slightly overlaps the index element output terminal- I anchor my Cases bottom right and drag up and left
The Case way drop with undefined data (black) tunnels or it may not appear however extending a wire from the index element will show "Ghost Tunnels" (grey floating boxes the same size as tunnels) if the wire path is near the area they are located.  Also Type becomes bad, drop a unbundle by name and you cannot select element and wires are black.
Explain errors will show VI failed to compile.
Save vi crashes with FPSANE error
VI can be recovered BUT crahses LabVIEW if opened.
(3,942 Views)
CAR 311775
(3,922 Views)
This bug has an interesting philosophical nature. LV does not like mobius strips or any other diagram that reminds us of MC Escher.
Ben
(3,893 Views)
