Case order of EVENT structure
It currently puts them back into the order that you created the cases in the first place - a feature which is 100% useless, as far as I can tell.
Alphabetical would make some sense as I can put the new DO IT 3 button handler right after the DO IT 1 and DO IT 2 handers, even if I've added more events after DO IT 2.
The only other thing I can think of would be to assign some priority, if I wanted to "squeeze every ounce of performance" out of it.  But that would mean some other property of the event I would have to manage.  Not worth it.
If sorting doesn't change the indexing order (i.e. the order it dispatches them), then I don't really care.  Just tell the truth in the HELP files.
Steve Bird
Culverson.com
LinkedIn
Message 11 of 11
(576 Views)
