Case structure condition question
For a case structure
I know that X>1 can be entered as 1..
Can this be entered into a condition?
0>=  X  0 <=1
(1,102 Views)
Accepted by topic author LED47
If you enter 1.., it means x>=1, not x>1 !
Cases are integers (Did you see the coercion dot when you wire something orange?!) and I cannot see the logic in your conditions ( "0>=  X  0 <=1" ) for example what does that second zero indicate?
You can make a case for "0, 1", if that's what you mean.
If you want to do floating point ranges, you can use the output of "in range and coerce". If you want to classify into several ranges other tools are available.
(1,099 Views)
Thank you that answered my question very well
(1,085 Views)
