Case structure
I have wired the Stop button to a case strucure to send out a zero voltage to my DAQ card Whenever Stop button is pressed ( When the case is true), as for the False Part of the case structure i dont want to wire anything to the DAQ card and as you know this will give you an error, what should i do for the false part if i dont want it to take any action in my program? Thank you
(3,803 Views)
hi persol
                        see the attached vi...i hope this help u..........
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
(3,796 Views)
Your question is very confusing, maybe you can attach the code you have so far for illustration. You seem to colloquially mix diagram wires with physical wires (wiring to the DAQ card vs. wired to a stop button, for example) and nothing makes much sense. Why do you assume that I know that "this" will give an error? I don't! What kind of error? Why? What is "this"?
Typically, if you don't want to "take any action" (and I am not even sure what that means), you would leave the appropriate case empty.
(3,787 Views)
hi altenbach
                        my previous post with zero_voltage.vi is an illustration.  if any  thing wrong . plz ...feel free to tell me
Indrajit
(3,778 Views)
hi
when you say 'this will give you an error', you mean 'case structure output tunnel will not be wired in the False case resulting in an error' ??
but what do you mean you dont want to wire anything to DAQ card? you dont want to generate any voltage? or what?
show atleast your B.D screenshot.
you have to wire any data to the case structure o/p tunnel. if you do not want to wire anything, what do you want to do??
you wish to let zero voltage continue on the DAQ channel? that sounds funny, though!Smiley Wink
details pleaseEE!!
(3,744 Views)
Thanks guys the problem has been solved
(3,712 Views)
