Cdaq analogue output wont update
I have built a labview code. I want the code to display the waveform of my voltage output. When I change my amplitude, the amplitude on the front panel changes however the signal on the scope does not.
(1,065 Views)
I am using cDaq 9189. I have built a code such that the voltage output can be displayed on a scope. When i change my amplitude input, the amplitude of the output on the scope on my front panel changes however it does not change on the oscilloscope.
(1,065 Views)
Hi shazzyk and mchssic,
why do you post the very same question with the very same attachment using two different forum accounts?
Why don't you team up in just one thread?
Btw. you would reach a broader audience if you would attach your VI using an older version of LabVIEW. (There's a "Save for previous" in the file menu…)
(1,043 Views)
