Center image and table in Standard Report
Team,
I am having an image and a table to be printed. I use the Standard Report format. Customer's requirement is to make the table columns to be of different widths, center the table and make the image to be of the same size as the table. I have achieved different column widths by customizing the Report Generation VIs. For the next items - centering the table & choosing the image size, I have considered A4 as paper size and set the left and right margins & set the image size accordingly. Now the problem is the customer prefers not to limit the paper size to A4. So is there a way to set the center-alignment to the image & table (instead of me setting the suitable margins to make it appear centered)? There is an alignment control in Append Image to Report VI, but this is not used by the Standard Report. Is there a workaround for this and the table? Any help is greatly appreciated.
P.S.: HTML report is not an option, since I need the ability to choose a printer and print to it from our software. HTML reports, by default, prints to the printer configured in the default browser, using the margins configured in the browser.
Priyadarsini S
Message 1 of 1
(2,570 Views)
