Certain frequency doesn't show up in the waterfall plot
Dear fellow LabVIEW experts,
I'm in need of help regarding the waterfall plot.
I have collected some data that contain high peak frequencies at around 2000 Hz and 6000 Hz (as appeared in the power spectrum graph). When I read the data using the Read from Spreadsheet vi, the 6000 Hz frequency did not appear in the waterfall plot.
So, I tried to use two simulated sine signals at frequencies of 3000 Hz, and 8000 Hz (Sampling rate: 250K Hz, No. of sample: 16384). Both frequencies showed up in the power spectrum graph and waterfall plot. But, when I changed the 8000 Hz to 8400 Hz, it disappeared from the waterfall plot (it was still showing up in the power spectrum graph). When I changed back to 8000 Hz, it reappeared in the waterfall plot.
Does anyone know why the waterfall behave like this?..Is there any limit of what the waterfall plot can display?
I really appreciate any help.
Thanks a lot.
(2,753 Views)
Hi Tronne,
Were you changing these values on the fly while the program was running, or between executions?
Product Support Engineer
(2,730 Views)
Hi James
I tried both, i.e. while program is running, and between executions.
Any idea why this might happen?
Thanks.
(2,727 Views)
Can you upload a copy of the sample VI you've developed with the sine simulation?
(2,700 Views)
