Change Desktop Theme when using NI Real-Time Hypervisor
I'm using NI Real-Time Hypervisor 2.1 with Windows XP FES and a PXI 8110 controller.
I want to use the Windows Classic Theme as shown in the following picture :
I then apply the new settings. But everytime I reboot, it sets back to the Windows XP theme (with the blue taskbar)
It works fine when I choose Windows from the boot menu but not when I run NI Real-Time Hypervisor (the settings where changed when I run NI Real-Time Hypervisor).
How can I make it work ?
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(2,891 Views)
Hello Helmut,
It might come only from Windows and not directly from the Hypervisor. Do you have checked if Themes are running in Services ? (source, French)
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(2,861 Views)
