Change Digital Waveform Graph data names to my Channel Name
I have a Digital Waveform Graph. It is beautiful. The digital waveform graph is not using my human readable channel name as the plot label though. Instead I am getting a plot label like:
cDAQ9185-1F11688Mod3/port0/line3
In my case this in not very helpful. When I define the channels there is a human readable name being defined like "Upper chamber switch".
How can I get my digital Waveform Graph to use my human friendly name (Upper chamber switch) rather than my channel definition string (cDAQ9185-1F11688Mod3/port0/line3)?
I HAVE tried the following but it did not work:
The channel names are confirmed as being there by checking Array 2 indicator values.
(2,152 Views)
Hi flycast,
what about reading the channel names from your waveforms as a string datatype instead of those variants?
(If you would post real code [aka VIs] instead of just images of code we would/could help much faster/better…)
(2,148 Views)
@GerdW wrote:
Hi flycast,
That sounds great. How? The only way I c an see to get a channel name is by using Get Attribute that returns a variant.
@GerdW wrote:
Hi flycast,
Yeah, I agree. In this case I am reading TDMS files, you would need the TDMS files and it contains confidential information. In some cases I have created simplified VI's to post.
(2,128 Views)
Accepted by topic author flycast
Hi flycast,
Reading the help for those functions would really help!
See this (I had to read carefully, too):
(2,121 Views)
Perfect GerdW - You are a genius! I read that but didn't clue in to what "NI_LineNames" meant.
(2,101 Views)
