Change Focus programmatically
how can I change the focus programmatically (runtime)? Two VIs are running
at the same time, and I want allow the user to change between those using a
menu bar without stopping the other (because they are synchronized and have
to run all the time - independent of the focus or if both frontpanels are
closed...
Have a nice day, RWS 🙂
-- PGP Fingerprint --
660F 9A2E 02B4 9E84 3A23 465B DF29 CE35 C797 F9C7
(3,307 Views)
Under Windows, you can use the Move Window to Top.vi from the Window Management
VIs section of the 32-bit Windows Utilities (lvwutil32.zip).
You can grab the 32-bit Windows Utilities from the NI Web site:
http://digital.ni.com/explprog.nsf/websearch/ebf11dd1f0feaef3862566790072a983
John Lum
(3,307 Views)
