Change Form Size during runtime
Could someone tell me how to change the size of my VI form during runtime?
I want the ability to click a button and have the height increase by 50 points or so, then go back to the original value after I click the button again.
Thanks for the help!
Angus Cattle from Pool Ranch and Steel Repairs via Joe's Welding.
(4,207 Views)
You can use the FrontPanel.WindowBounds property. Note that there is also a PanelBounds property. The difference is that the PanelBounds refers to the inner area, not including scrollbars, etc. See attached for a simple example (LabVIEW 8.2)
(4,200 Views)
Ok, that got me on the right track.
For some reason, though, my VI still does not change whenever I click the button.
I have attached my VI, saved in 8.2 format.
Does anyone see why my form doesn't grow by "98" whenever I click the "More >>" button?
(4,184 Views)
You have an error in your wiring. You're branching off the original bundle, rather than sending the new bundle out in the "True" case:
Message Edited by smercurio_fc on 01-04-2008 09:44 AM
(4,178 Views)
Hi jp,
you should wire the output of the "bundle by name" function instead of the original wire!
(4,174 Views)
Man. So simple!
Thanks, guys.
(4,170 Views)
