Change IP address to sbRIO
Is it possible to change IP address for NI-sbRIO9606 in labview code?
I am using LV2012.
(3,773 Views)
Real-Time>>Utilities>>RT Apply Target Network Setting.vi
(3,763 Views)
I don't have that vi in my functions.
(3,754 Views)
You need to install LabVIEW realtime.
(3,746 Views)
You could also try configuring remote target using network browser, https://decibel.ni.com/content/docs/DOC-12773.
(3,720 Views)
I have realtime module installed.
Using browser is not an option, I need to change ip address programmatically.
(3,680 Views)
JuhoR,
You can also use the System Configuration API to change the IP Address. I would recommend taking a look at the this example. It looks like they are doing something similar to what you are looking for. You can also change the IP address by accessing the sbRIO through FTP and modifying the NI-RT.ini file. The bottom half of the KB walks through that process.
Best,
Tannerite
(3,669 Views)
